Conrads X-10 Build Log
Date:  3-10-2009
Number of Hours:  6.00
Manual Reference:  none
Brief Description:  DuckWorks Aviation Leading Edge Lights
I purchased a set of DuckWorks Aviation LLC leading edge lights for the X-10 project. The cost was a reasonable $85.00 dollars each for the Rectangular RV-10 Installation Kit only. The installation instructions say that the light could be installed in only 2 hours however I found that for the first light installation 4 hours at least would be sufficient. I am using 14 gauge un-shielded 22759mil spec white wire for the 100 halogen light installation. Therefore I should have plenty of light for night time taxing, a total of 350 watts, two 75 watt Vans wing-tip lights and two Duckworks leading each light at 100 watts each.
Found at Web Site:
http://www.duckworksaviation.com/
Rectangular Mounting Plate
Cutt-out in the Leading Edge Left
Duckworks cutt-out
Duckworks cutt-out
