Conrads X-10 Build Log
Date:  10-22-2011
Number of Hours:  6.00
Manual Reference:  Supplemental
Brief Description:  Primer paint bottom of the fueslage with DTM prime
Oct 22 2011
I sanded smooth the first light primer coat of DTM white primer and any blemishes on the BOTTOM of the X-10. Not much fun rolling around on a mechanic creeper and a palm sander in one hand. And having debree adn paitn chips falling into your eyes. Then after masking off the fuselage and wiping the bottom with acetone, I applied another coat of DTM primer to the fuselage bottom, and allowed to dry before sanding with 360 or 400 grit sandpaper and then repeating painting and sanding one more time.
Time about 6 hours for both coats of paint and sanding.
