I trimmed the side windows to size using a Dremel and cutting wheel and smoothed the edges with a sanding block and 150 grade sandpaper. Everything was done at room temperature. I then bonded the windows in place using plastic "clamps" screwed into the fuselage. Clamps were removed after the epoxy flox mix had cured and r=the screw holes filled with same.
