Started landing gear mounts. These will mount to the main spar on the front. First step was to install landing gear leg (light sanding of inside of mount tube ensured good fit - used grease, too), align single bolt hole, then drill out in assembly. Instructions called for a .311 size drill - yeah right! They offered choice of using 5/16" if no .311, so that's what I used. Went well.
