Serenity
Date:  7-17-2008
Brief Description:  Baggage area
Finished bulkheads by creating the wear blocks that will contain the seatbelt anchor cable that runs from the shoulder harness through the bulkead to the anchors in the aft fuselage. Also fixed the rotisserie, since the steps on the fuse don't clear the cross bar (see pic 3).
Teflon like wear blocks riveted
View from baggage area - a cable will come out of the hole when the seatbelts are installed
Cut the 2X4, put a bottom plate so now the fuselage can rotate 360 degrees
