Serenity
Date:  7-4-2008
Number of Hours:  3.00
Brief Description:  Baggage compartment floor
Started on baggage compartment floors. I decided to add hatches to take advantage of some extra space between the ribs for storage and for the strobe power supply. I started by cutting the openings - drilled four corners with the step drill, then used the airsaw to cut between. A bit of filing cleaned it all up.
Cutting opening for hatch
Finished hole with power supply sitting inside
