Serenity
Date:  6-19-2008
Brief Description:  Install of steps, day 1
Started the steps - these are streamlined steel parts that attach by rivets to the side and also by a teflon block inside to a baggage rib. In pic 2, another use of the wonderful 90 degree angle drill attachment - I am drilling a #12 hole (just over 3/16") through the block and torque tube. A bolt here prevents rotation (as do a bunch'o rivets on the flange), then the block is bolted to the rib it sits against.
Primed
Primed
Looking down in the fuselage where the torque tube is attached to the rib.
Clecoing on the steps
