Time to assemble the F-904 bulkhead - this is the main wing spar attachement point which spreads the load to the fuselage. It comprises two 'beams' riveted together with some other parts. First, found all parts. Then, located all snap bushing holes (mainly for wiring pass through), drilled out to 5/8" with unibit.
