Serenity
Date: 11-15-2006
Number of Hours: 2.00
Brief Description: Trim tab
Bent the edges of other side of trim tab. Clecoed, spar, drilled, deburred, dimpled, countersunk. Instructions don't say, but the hinge is included in the above assembly. Lower spar/skin was riveted with MK-319-BS rivets. Fuel tank sealant was mixed (1 oz jar) and applied in a thin coat to the foam ribs, then they were applied and the skin clamped with the prior made v-clamps. Top spar to skin to hinge rivets were squeezed, and end tabs were done with blind rivets. Trim tab will be put away for a week for the fuel tank sealant to cure.
clecoed hinge/spar/skin
Generic Proseal applied to foam rib
All riveted, clamped, time to put away
