Serenity
Date:  10-9-2009
Number of Hours:  1.00
Brief Description:  Front cabin deck/sub panel - drilled skin
Clecoed on the top skin and drilled all holes except the 644 rib. I decided to do that one when I had the canopy hinge spacer blocks in place. Anyway, this is wraps up the fuselage kit instructions!!!! A milestone reached. Next will be to time to start the canopy work, all part of the finishing kit. There is a 'to do' list I have for more fuse work that I will wrap up this winter when I can't work on the glass canopy due to the cold.
Can see the instrument panel here.
Front top skin drilled and clecoed.
