Put together the control stick assembly - most of the time was spent cutting and adding new rib bridges to the seat ribs so the whole stick assembly can slide in. Otherwise, you have to put together the assembly in the ribs - not fun trying to fit those little washers.
Contril stick assembly - right/passenger stick removable. I will add spring buttons.
