Started construction of a fuselage rotisserie - used the old wing stands, modified them by clamping a pipe in copper 'bushings' to some braced angle. The pipe has a floor flange at either end - one end bolts to the fuselage via a wood plug I made for the firewall recess hole, while th eother end connects to a handle. I also added a round plate to the vertical upright that the handle rotates around - I can clamp or pin these two together to lock the fuselage. The tail was attached to the same pipe arrangement via wood bolted to the aft bulkhead. I guestimated the center of mass/roll and came out very close.
