Brief Description: More tank sealing, vent and fuel lines
Applied sealant to all inside rivet heads (used the Aircarft Spruce plunger/cartridges that fit the Van's gun - worked nice), and then fabricated, riveted, and sealed the end rib tooling hole cover plate. Also fit the fuel pick-up line and hardware, sealing where necessary, and lastly the vent line and hardware. All nuts torqued.
End rib, sealed
Example of a bay sealed, vent line and fuel cap flange seen
