Brief Description: fitted and drilled right fuel tank
Right fuel tank - clecoed Z-brackets, put in temporary pop rivets, fitted tank to spar/wing (pic). Back drilled spar to Z-brackets, tank to splice strip (#19 on all). I then tested wing twist with a plumb - perfect, no twist to 1/32" accuracy. Tank removed, then drilled out all rivet holes.
