Main spar and ribs were riveted. Finally have the damn offset rivet set and gun mastered (key is to tape the set and gun into position to avoid the set rotating, and to clamp your work and push the rivet gun harder to avoid bouncing the set and creasing the rivet head). The tungsten bar and mushroom bar made for quick progress. Lastly, I put the assembly on the wing stand.
