Serenity
Date:  3-9-2010
Number of Hours:  0.75
Brief Description:  secure rudder cable exit
Secured the rudder cable sleeve at the rear fuselage exit. Also temporarily installed a center console deciding whther I want one. I like the look, console mounted throttle, but disadvantages include restricted leg room laterally, difficulty getting under panel on my back (mitigate with access holes on top, and pull out large EFIS screens). After finishing some work and when ready for the canopy cutting, I may remove the fuse from the rotisserie, lower on sturdy legs so I can hop in and check clearances. Maybe make plane noises.
Hmm, should I put in a console?
