Brief Description: Installed Right Wing Access Panels
Completed right wing landing light installation. Fitted and dimpled right wing access panels. Located, drilled, and clecoed on fuel cap assembly and fuel sump. Milled out access hole for fuel pickup at fuel tank inboard rib. Drilled end rib accordingly for access plate. Deburred and dimpled leading edge skin. Test fit fuel pickup tube and anti-rotate bracket to right tank. Matchdrilled and deburred right fuel tank stiffeners.
