Brief Description: Match Drilled Joint Plate to Fuel Tank
Verified alignment of leading edge, fuel tank, and spar. Match drilled joint plate to fuel tank. Drilled hole in bottom side of leading edge for right wing tie down. Fabricated fuel tank skin stiffeners. Cut hole in leading edge for Duckworks landing light and (2) access hatches.
