Chucks Web Site
RV-7
Sec.7 - Wing
Dimpled Joint Plate, Skin, & Rib
Dimpled joint plate, skin and rib. Skin was dimpled with the standard dimple die. Joint plate with the tank die. Rib with substructure die. Parts nested together nicely. Assembled and test fit stall warning vane and mount.
RV-7 Home
562
Ailerons
Elevator
Flaps
Fuel Tanks
Horizontal Stab
Leading Edge
Vertical Stab
210
