Installed and match drilled W-408-I rib to left wing and installed joint plate. Drilled spar for stall warning wire. Installed 3/8 snap bushing in spar for wire.
Torqued bell crank bolt for the right wing.
Drilled left wing spar to rib attachment holes to full size. Drilled stall warning bracket to skin.
