Brief Description: Bent Outboard Edge of Trim Tab and Fitup
Bent outboard edge of trim tab using bend blocks. Aligned, drilled, deburred, and dimpled hinge along with trim tab and elevator attachment points. Trimmed trim tab hinge and fit trim tab to elevator. Drilled the remaining holes. Adjusted and aligned the trim tab. Dissembled trim tab for paint prep.
