Cut out all of the Elevator Ribs and smoothed the edges before fitting the ribs to the skin. Using the same method as Smitty and others on the web, fastened a piece of plywood to the side of the table to use to keep the elevator skin apart. Fitted all of the ribs to the skins. Final drilled all of the ribs and then assembled the spar and ribs and drilled all of those parts as well (no pics). Started deburring, dimpling and cleaning the parts
Getting the skins open to attach and drill the ribs
