Found out today that I had mis-manufactured the angle pieces that were the very first section of build for the HS. Have the order into Vans for new stock to remake those pieces. Did work on the rest of the HS. Deburring and fluting ribs (wow, not looking forward to this on the wings), setting angles on the inboard ribs. Final drilled all of the holes except the 18 needed for the angle brackets.
