Before I got too far on the wing assembly, I wanted to make sure that I had the wing lights in from PA so I could mount and wire during the assembly - they aren't in yet so I'm jumping to the bulkhead. Everything went pretty smoothly until 10.1, which has a 1mm difference in length between the A5 bolt I have and the one called out in the manual, so here I go trying to see if I'm supposed to use the one I found or if I need to order one because PA missed it...
