Connected the tail light and the pitch servo trim wiring. I hated the mini Molex connector for the trim servo so I changed it to a CPC connector but that is going to bee too bulky to attach securely in the area with the elevator pushrod. I removed the D-Sub pins from the connector and just used the male and female pins together with heat shrink which uses up 90% less space than a CPC and then the wire bundle easily attached out of the way of the pushrod.
Wiring for the FlyLeds tail light was easy and it is installed and ready to go.
