Well the stick fuunctions are not operating as they should based on the Tosten grip instructions and the main harness schematic. The PTT is woring off of the AP disconnect button and the trigger PTT is doing nothing. Had to cut open the wiring at the sticks and changs some wires around to get things as I want. Trigger is PTT, recessed button under trigger is TO/GA, top left button is AP disconnect and top right is nothing for now. The hat trim switch was working correctly. Got bot sticks changed over to the proper operation.
