Did some configuration in the GAD 27 logic controller, primarily the inside lighting circuits. Its very confusing all of the possible ways t control the DC and PWM lighting circuits from the 3 dimmer pots. I finally have them all working and properly too! The DC lighting I have going to the panels and GTN and AP panel so I can dim manually. The PWM circuits I have one for the dash switch illumination and a second to drive the overhead cabin LED light. The important thing with the PWM circuits is the circuits are controlled by the GROUNDS not the hot wire so I had to re-wire some stuff to get this right. The PWM circuit wires connect to the ground for the desired circit then you configure what pot does what on the G3X screen. Started running thermocouple wires for the CHT and EGT sensors
