Getting the wiring layout firgured out and made a plan for getting the main harness connected to my harness. There are a bunch of CPC connectore that I have to install ofn the main harness to get it all to work together. Installed the GTN and checked to make sure the back plate connectes engaged the unit completely and it looks fine. Installed the G5 standby EFIS to check harness length and will hook it up to the static/pitot lines once I get them cut and run from the AHARS unit first.
