Brief Description: Started installing avionics harness
Working on the avionics harness connections to the aircraft power system. Lots of ground wires to connect and power lines to the CB panel. I need to find a good way to attach the wires to the airframe, there are not more than a couple factory nut plates to use as ounting points for wire bundle loops. Mounted the AiRINC module and the remote audio box and connected them to the harness. Wires will be mounted securely after all is powered up and any issues are cleared up.
