Chris's RV-14A Site
Date:  1-28-2018
Number of Hours:  5.00
Brief Description:  Clean up center tunnel wires
Cleaned up the wires through the cener tunnel. The plastic push in clips that come in the kit are way too small to accommodate all of the wires on each side so I substituted some 1" plastic wire loops that attach with nuts and screws in the rear and the forward section has nut plates that I installed during the fuselage build. Trimmed and put the BNC connectore on the Nav and Com coax lines. The GPS WAAS lead needs threaded TNC connectors at the antenna and at the navigator and I have those on order now.
Cleaning up wire bundles
Antenna lead that attaches to right wing
