Finished the Flyleds controller installation. This took a lot longer than I expected as I needed to pull the main wiring harness on the left side to reroute the wires for the tail light to the controller board. The wires then had to be crimped and assembled into the DSub connector. Stillhave to finish tidying up the harnesses and get the new wires terminated under the dash and switches.
