Brief Description: Side flanges and top cowling fitting
Fit the top cowliing by sanding and sanding the rear edge to fit the firewall shape and also to provide the proper 3/16" spacing between the cowling and the spinner. Others have counted the number of times they took it on and off and said it was about 40 and that's probably about what I did as well. After that I added the side Skybolt flanges. These were spaced at 4 at 3 1/4" and the bottom one at 2 5/8". When planning the flanges to also need to make the spacing so that yoou avoid the engine mount bolt interference.
