Did the alignment for the nosewheel fairing attach brackets then set them into an epoxy / flock mixture the same as with the main wheel brackets. I waxed the brackets with parting wax then brushed on some PVA (parting film) and clecoed them to the wheel pant sides to cure. Drilled the holes for the spacer attach block hex bolts.
