Added the epoxy/flox mixture to the left pant to create the support area around the mounting brackets. I deviated from the plans and used parting wax and PVA release film on the brackets before embedding them into the epoxy. Coated the screws with parting wax so kee them from being permanently glued to the nut plates. The epoxy/flox is only to give added support area for the brackets and is not cosmetic which is good as it's not a particularly neat area once finished. The brackets popped right out once the glue was dry and they fit nicely back into the new support area.
