Installed the throttle and mixture cable pushrods. I have been waiting for an install kit from Airflow Performance since the stock kit routing for the mixture especially is completely wrong when you change to the FM-150 setup from the stock Silverhawk/Bendix style. This is a custom setup and all of the parts fit nicely and I hae them adjusted per plans.
**Update- you need to change the pushrod bracket for the mixture control rod different than in the instructions and different than this pic. The bracket needs to be turned around so that it is fcing forward, not backwards as shown here. Otherwise the extension will be short and there will not be as many threads of the rod end into the extension. It's probaby safe either way but the corect way engages the rod end 18 turns vs 8 the other diection. So make the mixture bracket face forward like the throttle bracket .
