Prepared the engine and prop for attachment.. Spent a lot of time figuring out the proper "clocking" based on the TDC of cylinder #1. The important timing marks are the TDC on the back side of the ring gear. When this mark in aligned with the top crankcase split then the engine is at TDC.
