Installed the fuel and oil lines from Aircraft Specialty. These lines fit perfectly and are all fire sleeved for better protection in case of fire. There are a couple custom lines they are making for me that are coming shortly. The manifold pressure line needs to be custom made to have a tap for the PMags to connect so that they have the manifold pressure reference. The line for th Airflow Performance needed to be custom as well as the length and fittings are different from the stock Silverhawk FI.
