I was going to remove the canopy to prep for painting and noticed the clearance at the rear is no longer to spec. All I can think is that it was trimmed back in the late Winter and now that it's hot out the clearance is not the same. In any case, it was trimmed again slightly to proper clearance and I guess in the cold the gap will be slightly too large but the bigger issue is that the canopy and rear window will have adequaite clearance in all temps. The trimmed edge will be final dressed with fine sandpaper again once the canopy is reoved for painting.
