Worked on the wiring and got the headphone jacks installed. The jacks come already wired to the main harness so it's not a lot of work here other than running the wires throught he seat ribs. Be sure the outside of the jacks do not tough the floor boards, they should not share a common ground with the aircraft. A quick check with a meter confirmed no continuity from the jack housing to aircraft ground. Did some more general wiring. So far it's been not too difficult although the wires from the harness to the control sticks are too short and I need to find a solution.
