More misc items today. Finished the cowling hinges including cutting angles in the loops for the curved areas. Spent some time figuring out the wiring pin code to interface with the Vans main wiring harness. The Tosten connector will plug right into the Vans harness which makes a nice setup. The c-8 grips have lots of features that you can use if you like. Remember "up" on the hat switch legend means forward on the switch which means "down" elevator trim!
