Lots of misc work today finishing up areas skipped earlier for one reason or another. I'm hitting a wall with finalizing a lot of things as the window plastic needs to be fitted before I can do these things but it's still too cold to be messing with the plastic. I have the stick bases permanently adjusted and attached as well as the cross link adjustedhave to and attached. On age 36-12 you have to add some washers aganst the link then insert the through bolt. Lots and lots of attempts with a lot of different ideas like taping the washers on first, and super glue tacking them but noting worked even closely. The last idea was to tack them with Gorilla glue with a tiny dab in 2 sides and let them rest with the bolt going through for a couple hours to dry. Well, this worked and the rods attached easily and the washers remained attached to the link and it was a 2 minute job to get it all bolted together now. The Tosten sticks are installed after adjusting the stick throws to the plans to see if they hit the dash area and they don't so all is good and the throws are within the minimum parameters in the plans.
