Did some miscellaneous work today and then put the elevator bellcrank assembly together. It took a while to find part(s) F-1037A the bellcrank brackets. They are from section 10-02 in the aft fuselage section. That explains why they don't appear in the inventory for the fuselage kit as you already have these parts and deburred and primed them (a year ago). Anyways, they are called bellcrank angles in section 36 but called battery angles in section 10. nc I found them its quick work to assemble this bellcrank assembly.
