Brief Description: Assemble cart for fuselage assembly
Built a cart for the fuselage assembly. This should be useful for assembly and for attaching the tail cone eventually and have everything able to move around the shop. The cart is based on the EAA 1000 work benches but sits only 24" high and is 12 feet long. The is no top so the fuselage can be rotated onto its side and worked on. The low height will allow reaching inside to buck rivets while standing next to the fuselage. No step stools or ladders needed.
