Chris's RV-14A Site
Date:  10-3-2018
Number of Hours:  4.00
Brief Description:  Install cooler and solenoid
Installed the new oil cooler and starter solenoid. Had to let the cooler sit for a while for the RTV to firm up from attaching the cooler ducting housing before I could install it back in place. Got the starter solenoid installed while waiting and this time I checked operation with a voltmeter and the starter wires disconnected to make sure it would turn on/off properly which it did. Got it all attached and spun the engine and got oil pressure after a few seconds of readng of zero. Follow the SB from Lycoming on this pre start oiling and its all straight forward when parts are not leaking or otherwise defective!
New cooler installed
