Shot the 2 coats of epoxy primer, this is DTM (direct to metal) primer to provide the stick between the aluminum skin and the paint coating. Followed up with a coat of white sealer coat. This was not required but gives a better base for the red top coat which would look much darker if sprayed over the grey epoxy. An hour later, I shot the white paint only in the areas which will be white in the final color scheme.
