Chris's RV-14A Site
Date:  7-20-2018
Number of Hours:  4.00
Brief Description:  Exhaust hangars and governnor pushrod
Installed the exhaust hangers for the Vetterman exhaust. One per side and attached to the engine sump bolts. The hanger rods need a flare in them so that the rubber flex tubes do not try and slide off from the vibration. Attached the hardware for the governor pushrod. Once in place, the pushrod gets sealed where it passes throught the rear baffle.
Exhause hanger rod flared
Left exhaust hanger
Left exhaust hanger
Prop governor installed
