Chris's RV-14A Site
Date:  7-8-2018
Number of Hours:  6.00
Brief Description:  Rear window install
Installed the seat belt attach wires and then installed the rear window with help from my wonderful wife. Its pretty straight forward as everything is already fitted and drilled etc. You need to mask the line from fuselage to window and then apply tank sealant to the window between the tape and the screw holes. You want to stop the water that might hit the window before it gets to the screws and weeps inside. The attach screws get snugged up but not torqued to the maximum so as not to put extra stress on the plastic window.
Installed the canopy side load pin modification kit. All straight forward and no issues getting everything to line up and function smoothly.
Rear window final install
Seat belt attach cables
Canopy side load pin socket
