Finished wiring the EGT sensors to the G3X and have the wires safetly tied off. I will do final wire bundling shortly. Checked out the readings on the G3X and all of the CHT and EGT sensors are reading room barn) temperature with no red Xs. Worked on trimming the bottom cowling a little more to clear the exhaust pipes. The cuts outs will need more trimming for better clearance.
