Installed the CHT and EGT sensors. The sensors come with a short lead that needs to be extended back to the engine sensor box. Thermocouple wire is on order to make these extensions. The CHT sensors screw right into the cylinders and are straight forward. The EGT sensors need an exact #30 hole drilled into each exaust pipe. These need to be exact to prevent any exhaust leak at the sensor locations. I used a #36 drill bit followed by a #30 reamer to make these holes. I finished up the PMag wiring and decided to add wires back to the cabin in order to make any future adjustment to the timing curves via the EICAD application. I ran these wires back to a CPC connector so I can plug into it with a dual pigtail made up of a Dsub connector for each ignition to plug into a laptop.
