Finished up the wiring in the tail. Installed the ELT audio alert to the bottom of the vertical stabilizer and secured the wiring to the ELT and tail trim and lighting. Added a .032 alum doubler and installed the transponder antenna and secured the coax. The GTX45 only requires one antenna for transponder and ADS-B so I have an empty hole forward on the belly that I will block off with a plate but leave available to remove should I need an antenna there later. Ran the coax for the GPS antenna that mounts on the top deck and routed and secured the cable. Ran a pair of wires for an overhead cockpit light that will be installed on the roll bar later. All of the rear wiring and static lines are now installed and secured and ready to fly.
